unhook reverse rev limiter on 94 400L 4x4
Old May 25, 2008 | 01:07 AM
teajay's Avatar
Default unhook reverse rev limiter on 94 400L 4x4
I have a 1994 400L 4x4 and the reverse rev limiter kicks in when you are going forward... and you cant get it to quit so you can ride it home. We have a Clymer Manual and are servicing the clutch, replacing the needle and seat in the carb, and replacing bushings in the rear swing arm... while we have it apart we would like to unhook the rev limiter if possible... It is not addressed in the manual... also where are the best places on the web for used/aftermarket parts? I have been getting the part number and searching google for them which works ok... is there any better way?
Old May 25, 2008 | 01:38 AM
Kerbbirds's Avatar
polaris has an online parts finder, polarisindustries.com as for the black wire, trace black wire from reverse override to the front control board under the front plastics and rack, and disconnect it.
Old May 25, 2008 | 10:57 AM
94harley's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: teajay
I have a 1994 400L 4x4 and the reverse rev limiter kicks in when you are going forward... and you cant get it to quit so you can ride it home. We have a Clymer Manual and are servicing the clutch, replacing the needle and seat in the carb, and replacing bushings in the rear swing arm... while we have it apart we would like to unhook the rev limiter if possible... It is not addressed in the manual... also where are the best places on the web for used/aftermarket parts? I have been getting the part number and searching google for them which works ok... is there any better way?</end quote></div>
What parts are you looking for? I just gutted a 98 xplorer(needed the motor) and maybe some parts will work for you?
Old May 26, 2008 | 08:06 PM
teajay's Avatar
we have a green, a purple, and a brown wire coming out of reverse limiter switch? which one would we disconnect to get the reverse limiter not to work?
Old May 26, 2008 | 10:58 PM
ftwflh's Avatar
There should be a black wire coming off the limiter.Follow it to the wire block and unplug it.
Old May 26, 2008 | 11:03 PM
Dirtbug65's Avatar
I have a 95 Sportsman and had the same problem and had to disconect the black wire from the rev limiter. The manual didnt really show where the rev limiter was so i had to go online to a parts fiche to zoom in on it. Should be behind headlight.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
