Trailblazer piston clearance
Old May 26, 2008 | 06:17 PM
harleypap's Avatar
Default Trailblazer piston clearance
Hi. Still have knocking sound. Tore motor down. Crank bearings are good, rod bearing is good. Wrist bearing is tight. Can anyone help me with the piston to cylinder wall clearance? Had a friend who is a machinist mic the piston and cylinder at the wrist pin of piston and center of cylinder. Came up with 4.5 to 5 thousands clearance. Can anyone tell me what the clearance should be? When putting just the old ring in cylinder I have about 3 thousand ring clearance. I don't have a service manual. Dealer not much help. Can anyone help with specs? This is a 2001 250 Trailblazer. Thanks for any help.
Old May 27, 2008 | 01:05 AM
MECHANIKE's Avatar
yeah i don't know what a 2cycle is but yours is 2-1/2 times my 4 cycle LIMIT of 2 thou,STANDARD CLEARANCE IS a half a thou.-- thou+1/2 at most.i don't think you should be running that loose even for a 2cycle.....get some specs at another dealer...
Old May 27, 2008 | 01:42 AM
03scrambler500's Avatar
Piston Clearance-Standard .0011"-.0021" Limit .006"
Ring End Gap-.009"-.018"
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
chewy78
Sep 8, 2015 10:37 AM
