Grizzly Grease...Do You Need It In There?
Old May 27, 2008 | 05:09 PM
Honeyduck96's Avatar
Default Grizzly Grease...Do You Need It In There?
What's your opinion on all the grease Yamaha stuffs into it's sheave? Is that stuff even necessary, or is it just to keep the noise down? It seems to me that it would just make it harder for the weights to slide out (especially in cold weather).
When I put the clutch kit in my Rhino, I cleaned it all out of the sheave. I applied a little to the sliding surfaces, but not the roller channels. It seems to be working good without, but I'm worried about doing damage.
Any input, knowledge or experience would be appreciated.
Old May 27, 2008 | 10:29 PM
DesertViper's Avatar
The grease works its way out of the roller channels after a few full throttle rips down the road anyway. You do need grease for the cam plate to slide as easily as possible, but you don't need as much as Yamaha puts in there. The design of the sheave, with the rubber o-ring that seals the outer edge, prevents the excess grease from getting out, so it doesn't hurt anything to have a little extra.
DV
Old May 28, 2008 | 05:33 PM
miassmaro98's Avatar
i used marine grease,and everything works fine
Old May 29, 2008 | 10:29 AM
ctateusa1's Avatar
I used grizz when I did my clutch work
Old May 29, 2008 | 06:03 PM
ATV_MAN's Avatar
Use marine grease, and only use a teaspoon per roller weight.
Old May 30, 2008 | 01:15 AM
same here
Pgbama11
Jan 16, 2016 08:19 AM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Pgbama11
Sep 10, 2015 08:20 AM
rawbdiggity
Sep 7, 2015 12:05 PM
