95 magnum 425 4x4 w/3000mi.
this thing keeps fouling plugs. i have cleaned the carb i put new needlejet and jet needle in it ran fine then it still carbon fouled the plugs so i raised the clip 1 notch on the needle and put a smaller main jet in it will ran fine for a while but it inevitabley will foul the plug. i also adjusted the fuel screw (manuel sez 1 3/8 turns out) but found that it needed to be at least 2 turns out then checked the plug and it was black on the rim and greyish on the tip. i can't seem to get it to be a tan color. does this carb need needle valve?
help please
help please
How did the condition start? Was it running fine and then out of the clear blue it just fouled a plug and continued fouling after you replaced the first one or...........?????? A bit more information would be a big help in guessing whats happening.
Sep 9, 2015 06:57 AM
