95 magnum 425 4x4 w/3000mi.
Old May 28, 2008 | 06:59 AM
cboo62's Avatar
Default 95 magnum 425 4x4 w/3000mi.
this thing keeps fouling plugs. i have cleaned the carb i put new needlejet and jet needle in it ran fine then it still carbon fouled the plugs so i raised the clip 1 notch on the needle and put a smaller main jet in it will ran fine for a while but it inevitabley will foul the plug. i also adjusted the fuel screw (manuel sez 1 3/8 turns out) but found that it needed to be at least 2 turns out then checked the plug and it was black on the rim and greyish on the tip. i can't seem to get it to be a tan color. does this carb need needle valve?
help please
Old May 28, 2008 | 07:20 AM
MaineWheeler's Avatar
How did the condition start? Was it running fine and then out of the clear blue it just fouled a plug and continued fouling after you replaced the first one or...........?????? A bit more information would be a big help in guessing whats happening.
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
Dan Newberry
Aug 30, 2015 09:42 AM
