hot rod crank and piston only way 2 stroke a warrior?
i was wondering if u can stroke a warrior any other cheaper maybe way then hot rods there so pricey and they say you have to use their stroker piston and was wonderin if u can use another piston 2 but mayb JE makes a stroker i dno any help thanks
FST strokers make more power than Hotrods strokers. The Hotrods are only +7mm, where the FST are +10mm. There is also another company than makes strokers for the Warrior that bumps them up to a whopping 460 cc, but I forgot their name.
Just sell the Warrior and buy a used 400EX - that will be a lot cheaper and easier and you will be able to keep up with your buddy with the 446.
