hot rod crank and piston only way 2 stroke a warrior?
Old May 31, 2008 | 02:01 AM
91Warrior357's Avatar
Default hot rod crank and piston only way 2 stroke a warrior?
i was wondering if u can stroke a warrior any other cheaper maybe way then hot rods there so pricey and they say you have to use their stroker piston and was wonderin if u can use another piston 2 but mayb JE makes a stroker i dno any help thanks
Old May 31, 2008 | 10:53 AM
Raptor450's Avatar
fourstroketech.net, but it's no cheaper at like $750, $1500 by the time it's installed.
Old May 31, 2008 | 11:07 PM
Octane2079's Avatar
500 dollars is pretty cheap in the scheme of things for a stroker crankshaft and piston.
Old Jun 1, 2008 | 02:29 AM
yea i kno bout fst...buddy of mine has a FST 446 warrior jus wonderin if any1 else made 1 and if u gota use hotrods piston
Old Jun 1, 2008 | 10:42 AM
Raptor450's Avatar
FST strokers make more power than Hotrods strokers. The Hotrods are only +7mm, where the FST are +10mm. There is also another company than makes strokers for the Warrior that bumps them up to a whopping 460 cc, but I forgot their name.
Old Jun 1, 2008 | 06:59 PM
Octane2079's Avatar
Nice thing about the 396 kit is you don't need the motor to be sleeved so it requires less machine work.
Old Jun 1, 2008 | 11:15 PM
Raptor450's Avatar
Just sell the Warrior and buy a used 400EX - that will be a lot cheaper and easier and you will be able to keep up with your buddy with the 446.
STLyamwar
Jul 25, 2020 04:44 AM
Divergent12
Dec 30, 2017 08:33 PM
robert301972robert
Aug 30, 2015 11:34 AM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
manuelrivera
Aug 8, 2015 04:34 PM
