98 Warrior will not fire up.
Old Jun 2, 2008 | 04:31 AM
Wookie11's Avatar
Default 98 Warrior will not fire up.
My 98 Warrior will not fire up, i was just trail riding one day and it died on me. I checked the plug and it was getting spark, so i checked fuel filter to make sure it was getting adequet fuel and it was so it led me to believe that the float was sticking or something. The carb was cleaned out and everything was put back together and it fired right up. It ran for a little bit but when you shut it off it doesnt want to start back up, you can bump start it and it will run perfect and even when you have it running for a while and shut it off you can fire it right back up, but just dont let it sit more then a couple minutes and or it wont start. It turns over and everything but doesnt fire up. I did replace the plug in it, but still the same problem. Please help me solve this. Sorry for this being so long.
Old Jun 2, 2008 | 05:12 PM
91Warrior357's Avatar
it almost sounds like fuel bowl is set incorrectly or something, does it stay running when choke is on? it back fire or bog or anything when you try to rev it up?
Old Jun 3, 2008 | 02:20 AM
Wookie11's Avatar
Do you mean bowl as it under the carb? if so i checked that out again and its fine.
Old Jun 8, 2008 | 02:05 AM
Wookie11's Avatar
I thought someone could help me on here, and so far i've had 1 response and 50 some views 7 of which are me. This site doesnt work. Someone help me please i'm loosing hope.
Old Jun 8, 2008 | 02:29 AM
check your park brake sensor just unplug c if dat cures it
Old Jun 9, 2008 | 02:31 AM
Wookie11's Avatar
I dont even have a parking brake on my warrior. where would the fuse be at if i have one?
Old Jun 26, 2008 | 05:42 PM
blasterboy1996's Avatar
300$ i will give u for it
Old Jun 26, 2008 | 07:32 PM
stickwithkarts's Avatar
Hey, i had a friend who had the same problem. It was his fuse, which is under the left rear fender. Give that a try, When that fuse is blown, your bike will do nothing.
Old Jun 26, 2008 | 09:06 PM
2Owanage's Avatar
Does the neutral light on if nto its probley the fuse if the light is on try pulling the clutch in and starting also try pulling it with a truck and putting it in to like 2nd or 3rd gear and see if it starts like that becasue if you can get it running that is not a lot of problems
