RAPTOR JETTING QUESTION
Old Jan 23, 2001 | 10:57 AM
RAPTOR1's Avatar
I have a full pipe on my bike and at the very top of the rpm range, it acts like its hitting a rev limiter and cuts out. It was 22 degrees out on sunday. We raced for an hour and a half and it acted the same all day. Does anyone know what condition could be causing this to happen?
any help is greatly appreciated
Old Jan 23, 2001 | 12:16 PM
redrocker's Avatar
155,160 mains
27.5 pilots
cut flaps out of snokle
Old Jan 23, 2001 | 01:04 PM
bartolo's Avatar
It's running too rich. Take the air box cover off and run it down the steet and see if that fixes it. If it does, you'll want to modify your air box since you need the lid to hold the filter in place. Mine did the same thing when I first jetted it and the air box modifications fixed it.
Old Jan 23, 2001 | 01:09 PM
RAPTOR1's Avatar
Thanks Bart. You are right too. The plug is black as can be. I am going to modify the air box tonight. hope this works
thank you for the help
Mike
Old Jan 23, 2001 | 03:42 PM
bartolo's Avatar
Mike,
Glad that helped!
Feel free to take a look at my lid modifications. It won't win any beauty contest, but it works! I used a dremel (I think that's what it's called) to do the cutting. I left the plastic alone that runs along the top of the filter, just in case any water came in it would not dump directly on top of the filter.
I took mine to the access road (it runs parallel to I-35) yesterday to try out the air box modifications to make sure it doesn't bog at top end. The speed limit on the interstate is 70 mph and it kept up with the cars w/o any bogging. Your's should now do the same.
Have fun...
Bart
www.members.home.net/bartkim
Old Jan 23, 2001 | 07:26 PM
2001raptorrules's Avatar
Why don't you try going down on the main jet size if you are to rich instead of cutting the airbox?
Seems simple to me.
Old Jan 23, 2001 | 07:30 PM
fast400's Avatar
my raptor was doing the same thing when i put a white brothers slip on exhaust on it and i just moved the needles up one posistion and i works better.
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
STLyamwar
Jul 25, 2020 04:44 AM
black_thunder
Jul 22, 2015 06:01 PM
yambam13
Jul 4, 2015 01:49 PM
