300EX rocker or cam knocking
Old Jun 4, 2008 | 03:41 PM
juttin_15's Avatar
Default 300EX rocker or cam knocking
either the rocker arms or cam is knocking, it only happens at high rpms.
Old Jun 9, 2008 | 01:01 PM
300exStroked's Avatar
are you sure its not the valves? real high pitched tapping sound
Old Jun 9, 2008 | 01:42 PM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
Have you ever had the valve lash adjusted? It needs to be done once in a while. It could also be detonation or carbon buildup. We used to have that alot in older cars before Fuel injection etc. Believe it or not, you could have enough carbon build up that it is knocking everytime the piston hits top dead center.
Old Jun 9, 2008 | 03:33 PM
juttin_15's Avatar
it only does it at high rpm, the engine had been blown up and i just rebuilt it, it has done this before, i swithched the cam and rocker arms and it stopped for about 2hrs.
Old Jun 9, 2008 | 03:35 PM
juttin_15's Avatar
the head had been setting for a while when i picked it up
Old Jun 12, 2008 | 08:10 PM
Did you use a new timing chain?
Old Jun 12, 2008 | 08:41 PM
juttin_15's Avatar
no
Old Jun 12, 2008 | 09:30 PM
BrandonKupihea's Avatar
I think its valve clatter. Try to readjust them. How many tanks have you run through the bike since the rebuild?
Old Jun 12, 2008 | 09:36 PM
juttin_15's Avatar
Old Jun 12, 2008 | 09:52 PM
I would readjust the valves bro.
