sputtering
Old Jun 6, 2008 | 01:32 PM
5lynchs's Avatar
Default sputtering
Has anyone figured out the common sputtering problem when motor is under a load. Mine is a 06' 450 sportsman
Old Jun 6, 2008 | 03:30 PM
JAMIEZ71's Avatar
Default sputtering
Never heard of this problem. Is it common the the smaller 450? I've had 500s and 700s, never any sputtering problem.
Old Jun 6, 2008 | 03:32 PM
Mongrol's Avatar
"Official Site Skeptic"
Default sputtering
<div class="FTQUOTE"><begin quote>Originally posted by: 5lynchs
Has anyone figured out the common sputtering problem when motor is under a load. Mine is a 06' 450 sportsman</end quote></div>
We need more info. What were you doing? What had you just done? Last service? How many hours? That sort of thing.
Old Jun 6, 2008 | 03:34 PM
5lynchs's Avatar
Default sputtering
I seen that other users had similar problems on several different models but know one said what had fixed it
Old Jun 6, 2008 | 03:37 PM
5lynchs's Avatar
Default sputtering
In 2wd or 4wd normal riding everything is fine when going uphill or in mud and sand it starts missing kind of the same way they do in reverse when you dont use the over ride button
Old Jun 6, 2008 | 03:46 PM
Mongrol's Avatar
Default sputtering
If it sputters under load and about the same rythme as the reverse rev limiter, it may be a fuel delivery problem. Fuel filter plugged, old fuel, dirty carb or float not adjusted. Possibly plugged jet.
Ride it again and when it happens, loosen off the gas filler cap and see if that helps. It it helps, it may indicate a plugged vent line, like a bug crawled in.
Could you be just over reving it?
Old Jun 7, 2008 | 12:31 AM
user493's Avatar
Moto Psycho
Default sputtering
I've never heard of a sputtering problem. I'll be watching this thread to learn more.
Old Jun 7, 2008 | 01:23 AM
Mongrol's Avatar
Default sputtering
Substitute "Missing" for Sputtering.
Old Jun 7, 2008 | 01:30 AM
user493's Avatar
Moto Psycho
Default sputtering
Yeah, but how common is that? I've never heard one do it.
ReconBayou
Oct 31, 2022 05:37 PM
ltrmc02
Aug 22, 2021 02:34 PM
Bernhard
Sep 25, 2015 12:45 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Hw00d
Sep 10, 2015 08:53 AM
