Sportsman 700 EFI 2004
Old Jun 9, 2008 | 06:00 PM
scubastev13's Avatar
Default Sportsman 700 EFI 2004
Any ideas why this machine runs real rich? did they have mproblems with injectors or somethig? Am i missing something? Any help would be appreciated.
Old Jun 9, 2008 | 07:23 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
make sure the asir filter isnt plugged or any vent lines. if not maybe the t bap sensor is bad causing it to go rich. check for any codes it might have.
Old Jun 9, 2008 | 11:35 PM
Air filter looks good. Wonderin if it ain't injectors. that is the code that comes up. code 51. not sure i tried different plugs. they seemed to help but not last. got rid of champions and went to ngk.
Old Jun 10, 2008 | 01:05 AM
user493's Avatar
Moto Psycho
If the code is telling you "injectors" than it must be an injector problem. Does your manual list several possible problems? My quad is totally different but a code 51 can be 4 different problems with injector #1 for cylinder #1. Code 52 would be the other side of the engine. If it CAN be multiple problems pick one, like a short circuit, check it and try to eliminate as many as possible.
Old Jun 11, 2008 | 06:07 PM
I talked to a local mechanic, and he said sounds like a power inverter or something loike that. he has 3 quads at his shop waitin for them. they r back ordered for a couple weeks
Jmuddin284
Jan 19, 2026 07:16 AM
COFatboy
May 2, 2020 12:06 AM
velcro7279
Aug 24, 2015 01:15 PM
bradco
Aug 21, 2015 08:11 PM
Stirling
Aug 9, 2015 01:49 PM
