shifter popping out of gear
Old Jun 12, 2008 | 06:30 PM
HARLEY_OWNER's Avatar
Default shifter popping out of gear
ok so i was searching on the forums but didnt see anything that suited this... my 94 400L 4x4 kind of pops outta gear easy...now it does once in a while for me but i noticed it more when my friend road it.. is there anything that wears out or could it be from not getting it put in gear all the way??
Old Jun 12, 2008 | 06:40 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is there adjustments on your linkage to adjust? does it only do it in forward and not reverse? maybe the everything like the joints are worn enough so the slop is not letting it go into gear all the way. just a guess.
Old Jun 12, 2008 | 07:09 PM
i think maybe it pops outta reverse more than in forword... where would i look for adjustments?
Old Jun 12, 2008 | 08:43 PM
700 sportsman's Avatar
right behind the shifter, i would also say thats the problem
Old Jun 12, 2008 | 09:00 PM
user493's Avatar
Moto Psycho
The threaded rods have a jam nut on them. Loosen the jam nut, adjust the length of the rod, tighten the jam nut.
Old Jun 12, 2008 | 09:22 PM
the rod? are you talking about the shifter... or somthing else... and do i make it shorter or longer?
Old Jun 12, 2008 | 10:28 PM
drlang's Avatar
Try the adjustment. BUT that probably won't work. That vintage transmission is known for this. I in fact am looking for one. Good luck Doc
Old Jun 12, 2008 | 11:10 PM
ftwflh's Avatar
Also change the oil in the shifter and clean the parts inside it.
Njrider1230
Jul 29, 2023 05:16 AM
merryman
Sep 6, 2015 10:20 AM
frostphase
Aug 19, 2015 07:11 PM
Schneider
Jul 24, 2015 05:05 PM
ghost civic
Jul 19, 2015 10:13 AM
