01 raptor starting problam
Old Jun 12, 2008 | 11:29 PM
livinloud9999's Avatar
Default 01 raptor starting problam
ok here is whats going on i cannot start with button (i have to push start and it will run fine) sometimes it will turn over 2 times and then click cilck click and a couple times it started right up. so i took the spark plug out and tryed to start and it turns over fine. i am stumped and legs are worn out form pushing can anybody help me...
Old Jun 13, 2008 | 01:58 PM
can any body help please?????????
Old Jun 13, 2008 | 03:15 PM
faponce's Avatar
Man I've been round and round with the click, click, click and in the end as long as you have not been doing any work on the bike it's the battery. You will probably check it with a meter and it will read 12v and your lights will come on so you will think I'm full of $hit but the most likely reason is the battery. Second to that it will be the starting relay but the fact that you hear a click means the relay is engaging. You can chech the starter if you want to pull it off and bump it to a good battery. Let me know how it turns out good luck.
Old Jun 13, 2008 | 05:36 PM
i will go get a new battery and try that. but i took the spark plug out to see if it would turn the engine and it will with no problams could the battery not be strong enough to turn the engine with the spark pulg in. thank you
Old Jun 13, 2008 | 05:49 PM
raptor8's Avatar
click click click means the battery is too low. try cleaning the terminals [the bolts] before you spend a ton of $ on a new battery - you may not need one yet.
Old Jun 13, 2008 | 09:54 PM
faponce's Avatar
raptor8 is correct when I was going through my problems I have several guys tell me the fixed theirs by cleaning the connections or they had dirty contacts in their on/off switch on the handle bars. Just take the battery to a auto parts store and get it load tested before you buy a new one. By the way I don't know what brand auto stores you have but I bought my battery at a Auto Zone for $64.99. 20 bucks cheaper than walmart.
Old Jun 14, 2008 | 12:46 AM
raptor8's Avatar
I have an 01 as well and just replaced the battery about New Years... not bad 7 years out of a battery. get a good one, sealed gel cell if you can. then it'll start right up.
Thank You Faponce, very polite of you.
Old Jun 15, 2008 | 01:30 PM
Thanks everyone for your inputs, I havent had time to clean connections and change battery but will do and will tell everybody the results thanks again.
Old Jun 15, 2008 | 07:13 PM
StngGT350's Avatar
man i had many clicks with my 60. but here is a good test for your battery. i made a set of jumper cables from some speaker wire and clips. i would jump it from my other quad. it no clicking and it starts right up, well time to get new battery. and if i have clicking,, well time to get out the electrical meter and start looking. but most of the time i found the batter is weak, might hook a charger on it or i need to get a new pattery. i have a 660 and a 350. so over 5 years of having both,,i think i bought about 3 or 4 batteries. those jumper cables on a ride, few buddies left lights on and they had a clicking sounds. but good luck!!
AtvManiac78
Jul 11, 2015 03:20 AM
VascoConroy
Jun 12, 2015 10:30 AM
1000gade
May 27, 2015 12:37 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
