blaster just takes too many kicks to start
Old Jun 17, 2008 | 07:42 PM
wmtitan024's Avatar
Default blaster just takes too many kicks to start
what could be the reason y my blaster takes a good amount of time to kick start? it runs fine jus takes like 20 to 25 kicks and its hot outside. o and in the winter when i rode it 1 damn kick is all was needed i dont understand.
Old Jun 17, 2008 | 08:03 PM
Sparta4188's Avatar
When was the last time you did your top end?
Old Jun 17, 2008 | 08:08 PM
wmtitan024's Avatar
idk i bought it used i never did the top end is that what it could be?
Old Jun 17, 2008 | 08:13 PM
hotblooded's Avatar
Like Sparta4188 meant it wouldn't hurt to check your compression. It could also be in your carb. Durring the winter(cold) months it starting good because it may be flooding out when it is warm out. Check your air/fuel idle screw for one. I beleive mine is backed out 1 1/2 turns. If this doesn't help it may (carb) just may need to be cleaned thouroghly. Yep;, your right it can be frustrating, check one thing at a time so you will know what helped and what didn't
Old Jun 17, 2008 | 08:18 PM
wmtitan024's Avatar
thanks for advice now is this something that can get worse? not sayin im goin to leave it go ill do something im jus wondering.
Old Jun 17, 2008 | 11:38 PM
Raptor450's Avatar
If it's not that, you could be running too rich. The cold weather leans the engine out and it starts fine. Then the hot weather richens it up and then it's too rich to start properly. Normally an engine that hasn't been cranked for a few days likes a richer mixture, unless it is WAY too rich.
Old Jun 18, 2008 | 10:17 PM
embler's Avatar
I would check compression first. you can borrow a compression tester from many autopart stores. get it cranked up and warm, shut if off, pull the plug and screw in the tester. hold the throttle wide open and kick it a few times. see what the reading is. then take the tester out and pour in a little bit of oil into the spark plug hole. screw the tester back in and kick it a few more times. if the reading goes up a lot, say going from 90 to 130, then the top end is worn out.
Old Jun 18, 2008 | 10:33 PM
wmtitan024's Avatar
ok im goin to check my compression but if it isnt that can it be a dirty air filter?
Old Jun 19, 2008 | 07:58 AM
embler's Avatar
a dirty air filter will choke it down. have you tried a new plug?
Old Jun 19, 2008 | 02:51 PM
wmtitan024's Avatar
i checked compression, it went from a lil over 90 to 110. its not my spark plug its new. when i warmed it up i rode it around and let it idle for a lil. then it jus died. then i checked compression and got those numbers and couldnt get it started again. it wanted like it was close but i jus got tired. i think it might be my carb or air filter? possibly?
