temp gauge
Old Jun 17, 2008 | 11:47 PM
jvog's Avatar
Default temp gauge
First off, I have a 1999 Polaris Sport 400L. I unplugged the sensor at the top of the radiator to see if the fan turned on and the hot light lit up. Please correct me if thats the wrong way of checking that. The fan didnt turn on the light didnt light up so I have come to the conclusion that I need to at least get a temp gauge. I've been reading other posts about installing temperature gauges and have read its better to put them directly on the head but I couldn't find the hot light sensor thats supposed to be on the side of the head. Can anyone give me a good description of where to find it? Also, the mechanical gauges seem to have a long sending you and wasn't sure if that would cause a problem. Thanks for any help
Old Jun 18, 2008 | 12:21 AM
roadney's Avatar
Default temp gauge
I bought a temp gauge at autozone for $16. They is the hot light sensor on the top of the head. If you remove this there is an adapter in the kit for the temp sensor and it screws right in. I installed mine last weekend and it works great I was having the same problem as you and yes mine was running hot and I didn't even know it so I had to fix the fan.
Old Jun 18, 2008 | 06:57 PM
jvog's Avatar
Default temp gauge
Ill look a little harder and see if i can find where it is on the head.thanks
Old Jun 19, 2008 | 12:21 AM
roadney's Avatar
Default temp gauge
It is on the back right side you have to move the gas tank to get easy access to it.
Old Jun 19, 2008 | 09:40 AM
MaineWheeler's Avatar
Default temp gauge
Hey guys what temps your machines running at according to your gauges? and have you noticed what temp your fans kick on at? Thanks
Old Jun 19, 2008 | 10:52 AM
roadney's Avatar
Default temp gauge
The fan should kick on around 185 and the hot light should come on around 205
Old Jun 19, 2008 | 11:41 AM
jvog's Avatar
Default temp gauge
is it possible to find the sensor without taking off the gas tank? and if i replace the sensor with a temp gauge the light wont work anymore right? I am pretty sure it doesn't work now I am just curious
Old Jun 19, 2008 | 01:07 PM
Default temp gauge
If you replace the sensor with a gauge your temp light WILL NOT work because your breaking the circuit.
shimanok2
Jan 29, 2016 07:37 PM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Halffast17
Sep 11, 2015 02:30 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
