engine brake system?
Old Jun 21, 2008 | 01:16 AM
fonzythehobo's Avatar
Default engine brake system?
i just bought a 2006 sportsman 450. the guy i bought it from said it had EBS on it but it only slows it down when i hold my rpms up. it also seems like the clutch is not kicking in as early as my other wheelers (04 sportsman 500ho and 03 sportsman 700) at about 3000rpm. are those signs of a bad belt??? my other question is without looking at the sticker on the side how can you tell if it has EBS
Old Jun 21, 2008 | 01:25 AM
user493's Avatar
Moto Psycho
EBS belts have grooves running all the way around the inside surface, non-EBS belts don't. If you don't have an EBS belt then you don't have EBS.
Old Jun 21, 2008 | 01:30 AM
if i was to swith out belts would ebs work or is there more to it than that
Old Jun 21, 2008 | 01:33 AM
user493's Avatar
Moto Psycho
It has to have EBS clutches. It's expensive to change them, but worth it IMO if you ride in hilly areas.
Old Jun 21, 2008 | 01:37 AM
but do you know what are the simptoms of a belt going out?
Old Jun 21, 2008 | 01:43 AM
user493's Avatar
Moto Psycho
A badly worn belt can cause it to run a little slower and at higher RPMs and cause the clutch to not engage until it's at a higher rev than normal. I don't know what else they do besides explode if they're burnt. I never really wore one out but blew 3 of them over the years.
Old Jun 21, 2008 | 03:41 AM
duster's Avatar
I'm pretty sure the Sportsman 450 didn't come with it stock because I am pretty sure I looked at a leftover yellow one.
From your description it also sounds like you were lied to.
It would have some hold-back when letting off the gas.
But it would not come on as soon or as strong (nature of the differences)
At certain points the belt would disengage and you would have no hold-back (down low)
Old Jun 21, 2008 | 08:19 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
06' sportsman 450 DID NOT come w/ ebs.
Old Jun 21, 2008 | 12:44 PM
TLC's Avatar
TLC
<div class="FTQUOTE"><begin quote>Originally posted by: jumbofrank
EBS belts have grooves running all the way around the inside surface, non-EBS belts don't. If you don't have an EBS belt then you don't have EBS.</end quote></div>
My ATV has EBS on it ,sticker and behavior.and it has the smooth outside like a normal sled belt.
Here is a video of EBS Polaris with the smooth belt also.
Old Jun 21, 2008 | 01:35 PM
sheepdogMSP8117's Avatar
I think he said inside of the belt. Looks like the grooves are cross ways rather than long ways.
