SP500 carb help
Old Jun 21, 2008 | 10:34 AM
79hugger's Avatar
Default SP500 carb help
Hi,I've posted a while back on this issue which is pretty crazy.I have a 98 sp500 I bought originally for parts that needed a cam, the previous owner said he also had carb issues prior to the wiped out cam.I replaced the cam with a Scrambler 500 cam, cleaned the carb and it run. With the air box connected it will run 47mph wide open, with the filter completly removed "just the tube to air box 47mph", if I disconnect the tube from the carb it will run 63mph according to my gps and my buddys Can am. Am I missing something, how can it run 63mph with nothing hooked to the carb and how can just the tube connected to the airbox with no filter or lid on the box make such a difference in top end speed "it's just a hollow tube"??
Old Jun 21, 2008 | 11:25 AM
[img]i/expressions/face-icon-small-happy.gif[/img] check jetting and also look for worn needle and seat.With no filter air increases allowing to run leaner. Test run,kill ignition,check plug color to see if too lean also.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
