Wont turn over
Old Jun 23, 2008 | 10:53 PM
Da-man's Avatar
Default Wont turn over
OOPs I just posted this in the big suzuki section.
My neighbor just gave me a like new 2003 80 suzuki 4-wheeler and said it needed a battery. I put in a new battery and the kids rode it around for a couple minutes then it died. The starter wont engage now and it just makes a ticking sound under the seat. I think it is a relay the little black one with 4 wires going into it. If that is what it is. The battery is still good. any help guys
Daman
Old Jun 24, 2008 | 08:42 AM
oblytr8's Avatar
I would check for voltage making it to the starter. The relay between the battery and starter may be toast. Use a multimeter to check the starter leads for the presence of voltage while someone hit the start button. If voltage never makes it to the starter, work back from there. I would also check to verify the battery still has a charge. A weak charge will only provide enough voltage to give you the "ticking" you are hearing.
Old Jun 24, 2008 | 08:46 AM
Da-man's Avatar
I checked the battery but will check the voltage going to the starter just to make sure. The reason I think it is the relay is because it is whats making noise not the starter. Is there any way to pass the relay and go straight to the starter? Just fishing here
Old Jun 24, 2008 | 09:04 AM
oblytr8's Avatar
You can, but the relay is what tells the starter when to engage, and when not to engage. Bypassing the relay to the starter would be like taking a screwdriver and arcing the solenoid on a car. You can do this is as test to rule out the starter if you wish.
Divergent12
Dec 30, 2017 08:33 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Jul 30, 2015 09:39 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
