Raptor jetting question # 43682
Old Jan 24, 2001 | 07:59 PM
bash's Avatar
I know there have been a lot of discussions on jetting for the Raptor, but most have revolved around jetting with a pipe and airlid removed.
I want to keep my lid on, but with the snorkel restriction removed and the baffle removed. Has anyone come up with a workable solution for this?
I'm at 400ft above sea level. I was thinking about 27.5 pilots and 160/165 mains. Anyone care to comment? I'm hoping that I won't have to do it 3 or 4 times to get it right.
Old Jan 24, 2001 | 08:05 PM
redrocker's Avatar
Bash
if thats the stock pipe I would go
with 150,155 mains may be even145,150
but yes on the 27.5 pilots
Old Jan 24, 2001 | 08:29 PM
bash's Avatar
I'll probably go with the larger of your two options then. With the 140/145, it bogs severely when I hit the next gear when I have the rubber flaps in the snorkle removed.
Old Jan 24, 2001 | 08:31 PM
bash's Avatar
PS... you should have my email, but if not, thanks so much, for such good dealings. The 2 extra gifts were great!
I'm here to say that if anyone ever conducts business with RedRocker, you can expect someone who really goes out of their way to treat you right.
I gotta get some sleep
Old Jan 24, 2001 | 08:47 PM
chasman's Avatar
bash
go to http://www.dynojet.com there kit is set up for what you are describing. I have that kit and will have it installed soon.
Chasman
01 blk/wht raptor
Old Jan 24, 2001 | 09:23 PM
dsEATER's Avatar
mine runs GREAT, lid on, 6 1" holes in it with uni vents, snorkel off, divider cut out> see it at my site http://www.geocities.com/raptorterry
needles dropped all the way
27.5 pilots (but plan on trying 25's)
152.5 & 157.5 mains
air screws in 1/2 turn
Old Jan 24, 2001 | 10:56 PM
400exrydr's Avatar
Nice website, DSeater!
Old Jan 24, 2001 | 11:05 PM
No2StrokeBs's Avatar
If you are not going to be doing any serious mud riding I would seriously recommend the removal of the air lid. I have the full BG system and the Pro design filter kit, I am running 165, 170 with 27.5 pilots, and it ran ok with the filter lid on and the baffle cut out, but it really picked up just by taking the filter lid off, but every bike is different, try it just to see
Old Jan 25, 2001 | 03:12 AM
Raptorup's Avatar
Chasman,
I ordered the same kit...tell me how yours comes out...if this don't work, I think Redrocker has the key...I'm not chasing my tail on this thing, but I can't even get the damn pilot here. Support sucks, so its the Dynojet for now. Later.
Old Jan 25, 2001 | 09:13 AM
garyc660R's Avatar
Bash....I am runnin' the snorkle off with the baffle removed. With the snorkle off, I used a small automotive breather for the crank case vent and zip-tied it out of the way. Anyways, I have raised the needles one notch, went to 25's on the pilots, up to 145/150 on the mains, and the turns out on the adjustment screws are 3 and 1.5. There was much trial and error on the adjustment screws, but that's where I wound up. No bogs anywhere and strong bottom to top. I have also gone up to a 14 tooth front sprocket and acceleration is stronger than with the 13 tooth sprocket (I confirmed this by racing my bro's 00 Banshee back to back many times one evening). Also tried the 14 tooth set-up with 22 inch tall tires and acceleration fell off. Hope this helps. Later.
