Need a new Starter Clutch For an Extreme 150
Old Jun 28, 2008 | 12:02 PM
SherpaT350's Avatar
Default Need a new Starter Clutch For an Extreme 150
I need a new starter clutch for a CVT Extreme 150. The clutch flew apart so there is no repairing.
Where would I get parts for this atv.
Thanks So Much,
D.
Old Jun 28, 2008 | 02:16 PM
luvmysxs's Avatar
your extreme 150 uses the honda gy6 engine, this is the same engine as every other chinese 150 uses. here's just one link, you can also find these on e-baystarter clutch
Old Jun 28, 2008 | 03:32 PM
SherpaT350's Avatar
That one doesn't look the same,it has a keyway and this one has a splined shaft.Here are some pics.The clutch has been repaired before as the screws must have came out and someone welded it.
Thanks,
D.
http://s37.photobucket.com/alb...50starterclutchII.jpg
http://s37.photobucket.com/alb...t=150starterclutch.jpg
Old Jun 28, 2008 | 05:25 PM
luvmysxs's Avatar
after searching the net for the last 60 minutes, i came to the conclusion you just might have a problem finding one that uses a gear instead of the keyway, i found about a dozen starter clutches for the gy6 from all types of dealers (they all looks all the same) that uses the keyway but none with the gear. lot of luck, i think you're going to need it.
Old Jun 28, 2008 | 06:29 PM
SherpaT350's Avatar
I got you beat on the 60 minutes. I agree I am in need of some luck. I guess I am also confused about the whole Extreme brand in itself. Is it extreme ,xtreme, or Baja Motorsports. I would call a brand specific dealer if I only knew whom to call.
Thanks,
Raz
ghost civic
Jan 15, 2020 07:43 AM
Cummins Driver
Sep 11, 2019 01:22 PM
ghost civic
Jul 15, 2015 10:48 PM
