Need a new Starter Clutch For an Extreme 150
your extreme 150 uses the honda gy6 engine, this is the same engine as every other chinese 150 uses. here's just one link, you can also find these on e-baystarter clutch
That one doesn't look the same,it has a keyway and this one has a splined shaft.Here are some pics.The clutch has been repaired before as the screws must have came out and someone welded it.
Thanks,
D.
http://s37.photobucket.com/alb...50starterclutchII.jpg
http://s37.photobucket.com/alb...t=150starterclutch.jpg
Thanks,
D.
after searching the net for the last 60 minutes, i came to the conclusion you just might have a problem finding one that uses a gear instead of the keyway, i found about a dozen starter clutches for the gy6 from all types of dealers (they all looks all the same) that uses the keyway but none with the gear. lot of luck, i think you're going to need it.
I got you beat on the 60 minutes. I agree I am in need of some luck. I guess I am also confused about the whole Extreme brand in itself. Is it extreme ,xtreme, or Baja Motorsports. I would call a brand specific dealer if I only knew whom to call.
Thanks,
Raz
Thanks,
Raz
150, 150starterclutch, 350, atv, baja, clutch, cvt, extrem, extreme, extreme150, motorsports, replacement, starter, starters, video, xtreme
