83 big red
like the title says....
I have the gear case off that holds the gears for high and low, and there is a seal on the shaft that holds the shaft in thats hiding the front sprocket...should it pull out if i used a puller? or do i have to take something else apart?
thanks
parts diagram for the front sprocket
thanks
You need to take a lot more apart. No puller needed. remove all the internals of the subtrans (hi/lo), Remove the recoil, stator assembly (you have to remove the bolt from the center of the flywheel to get it off, so you need something to keep the crank from moving), starter gears, and finally the case spacer plate. Then you can swap the sprocket and put it all back together! The manual wasnt much help. I just used the expolded parts view as mentioned earlier to get it all back together.
