400ex shocks on blaster
I read you'd have to drill out the shock mount one the bottom of the 400ex shock for the 12mm blaster bolt. and somehow drill through the casehardend steel for the stock blaster bolt 14mm on the top the use washers as spacers to keep it from moving around. then cut out the airbox so you can fit the rezzie. I heard that a honda 250r shock would also work will you have to modify it the same way. And would it be the ATC or ATV one.
