Sport Quads Discussions on sport quads.
400ex shocks on blaster
Old Jun 29, 2008 | 09:38 PM
HONDA_ATC_ADDICT's Avatar
Default 400ex shocks on blaster
Can i put 400ex shocks on a blaster. If so is it just a simple unbolt old shocks and put 400ex shocks on. or will it be a pain in ****.
Old Jun 30, 2008 | 01:50 AM
I read you'd have to drill out the shock mount one the bottom of the 400ex shock for the 12mm blaster bolt. and somehow drill through the casehardend steel for the stock blaster bolt 14mm on the top the use washers as spacers to keep it from moving around. then cut out the airbox so you can fit the rezzie. I heard that a honda 250r shock would also work will you have to modify it the same way. And would it be the ATC or ATV one.
Ahtatu
Sep 28, 2015 12:14 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
