Sport Quads Discussions on sport quads.
raptor 700r or 450
Old Jul 3, 2008 | 12:23 PM
hummer93516's Avatar
Default raptor 700r or 450
Im looking to get a new atv. Im looking at the following, raptor 700r, kfx450, and the ltr450.
Im was only looking at getting a fuel injected one.
Which one is the best overall?
also performance and speed wise?
Old Jul 3, 2008 | 12:33 PM
Krait's Avatar
What do you want to do with it? Trails, track, racing, mx, xc...? The LTR450 is best stock for mx, the KFX450 would be better for xc riding, Raptor would be best for all-round riding out those three...but worse for mx. The 450's will rev a lot more, but that means more clutch work in general trail riding.
Need some more info on how you ride.
-Krait
Old Jul 3, 2008 | 02:56 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I have ridden the Raptor and the KFX quite a bit, but not the LTR so I won't comment on it (might be to wide for trails though?). If you are stuck on fuel injection, the Honda 450 may get it this year (???), but the YFZ did not.
I find the Raptor 700 to be kind of quirkey. Its ergonomics just don't agree with me. It also carries its weight a little high in the frame. I wouldn't exactly call it tippsy (like the Raptor 660 absolutely was!), but it sure isn't low and stable either. Folks fall in love with that torquey bottom end, but it falls off the powercurve kind of early compared to the 450's.
The beauty of the 450's is the very favorable power/weight ratio! The KFX450 is ok, and among the 450's it has the most luggable engine, so I don't mind it for trails as much as the others. I do like that it has kind of quick razor sharp steering.
Old Jul 3, 2008 | 03:10 PM
i ride in open areas mainly, roads( dirt and pavement), some trails. but more so open areas.
I also heard that the ltr is the fastest stock outta these.
Old Jul 3, 2008 | 03:22 PM
How much better are fuel injection then a normal carb?
Old Jul 3, 2008 | 03:26 PM
DODGE57HEMI's Avatar
Mopar Man!
If you ride at higher elevations nothing beats EFI and since you said best overall quad nothing beats a Raptor 700!
Old Jul 3, 2008 | 03:40 PM
Krait's Avatar
If you want a 450, and ride in open areas, then why not expand your options. The LTR is great stock at mx, or open areas with smoother surfaces. The 50" width and tiny little mx tires just don't work well on tight trails and rougher terrain.
If you ride a lot of pavement, and smoother areas, then the LTR probably will do fine. Another 450 with EFI is the DS450, its supposed to have great topend...not so much lowend.
-Krait
Old Jul 3, 2008 | 03:51 PM
How does the ltr compare to the raptor topend wise?
Old Jul 3, 2008 | 05:11 PM
Mopar Man!
I don't know witch is faster out the box but 700 built will walk all over just about any atv. The aftermark support for the Rap is twice that of the LTR!
Old Jul 3, 2008 | 05:13 PM
bigned1904's Avatar
imo the aftermarket support the raptor 700 get is a good if not better than any other 4 stroke out there. the only thing that has even close 2 as much is the yfz450 and the trx450r
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 12, 2015 09:39 AM
black_thunder
Sep 6, 2015 04:41 PM
