warrior doesn't start unless pull started
Old Jul 7, 2008 | 07:02 PM
soillwarrior350's Avatar
Default warrior doesn't start unless pull started
Ok here is the deal was out ridin everything fine until I shut off ,then it wouldn't start.It is like the starter is not engaging,so I pull started (pop start) ran normal likme nuttin wrong so took it home pulled stator cover off starter is turning but not turning flywheel,think it is the starter clutch but not sure any help would be apprecviated and if it is the starter clutch is there a way to pull the flywheel off without buying the flywheel puller
Old Jul 7, 2008 | 10:46 PM
91Warrior357's Avatar
well once you determine whether or not the starter is turning the engine or just spinning freely it would prolly be a starter clutch most likely, and its reccomended to buy the puller around 50 bucks i think, that way you dont mess anything up but you can take a hammer and something to pry with and pry on the flywheel and smack the head of the shaft it slides over and sometimes they pop off if you do it right, but be carefull
Old Jul 7, 2008 | 11:48 PM
yeah it doesn't turn the engine over,I'll probably just get the puller tanks for the info
Old Jul 8, 2008 | 11:40 AM
54warrior's Avatar
I loaded mine in the truck, took it to the dealership, and they removed my flywheel for $15 while it sat in the bed of my truck. I did of course have everything disassembled up to that point for them though.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Dammar
Nov 14, 2015 07:41 AM
Dame0927
Oct 29, 2015 10:13 PM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
