vbike rear suspension upgrade
Old Jul 8, 2008 | 02:40 AM
offroadatvs's Avatar
Default vbike rear suspension upgrade
im thinking about changing the rear shock and put something else in, any ideas what would work?
i have a vbike 250-v4s and i want something that will lower the rear end just a little because i think it sits a little high and i want it to be soft because right now mines pretty stiff. i like the front suspension on it, its pretty soft and it does great.
Old Jul 11, 2008 | 11:38 AM
Coloradotrailrider's Avatar
I don't know what other shock would work but the one you have now is adjustable. The shock has a couple of large nuts at the top, one is a lock nut and the other is the adjuster nut. A spanner wrench is the correct tool to use but most of us don't have one. I did the backyard mechanic way of adjusting it. I took a large flat bladed screwdriver and a hammer and tapped the upper lock nut loose. Then I turned the adjuster nut counterclockwise, as you stare at it from above, and released abunch of tension from the shock spring. This softened the shock up quite a bit.
Old Jul 11, 2008 | 11:53 AM
thanks for replying. i will look at it in a couple hours and mess around with it.
im gonna have to check all the bolts and things like that since me and a buddy are gonna go mud bogging and the day after go to an offroad park.
vbike 250-v4s
renthal bars
renthal chain
Bratman2
Aug 6, 2022 01:42 AM
Asaran
Oct 8, 2015 11:14 AM
bigred20653
Aug 31, 2015 12:41 PM
DFWSRT8
Aug 20, 2015 09:24 AM
house1
Aug 9, 2015 10:49 PM
