200x carb work for a 200s?
Old Jul 9, 2008 | 03:36 PM
MonkOFox's Avatar
Default 200x carb work for a 200s?
Just wondering if my 200x 3 wheeler's carb repair kit would work for a 200s carburetor.
Didn't realize there was an atc forum.
Thanks,
Monk
Old Jul 9, 2008 | 11:51 PM
SMFREY's Avatar
They do look simmilar
Other than the needle and jet
I would give it a try
Good luck
Ray
Old Jul 10, 2008 | 01:27 AM
MonkOFox's Avatar
thanks, I went ahead and took it apart and soaked the carb for about an hour, cleaned it off, put it back together and it is idling and running just fine now. but when I gas it in neutral it kinda boggs down. What could cause that?
Monk
Old Jul 10, 2008 | 01:39 AM
SMFREY's Avatar
Needs fuel
But I would start with basics
check valve adjust
set timing
if still bogs
adjust needle in carb up to next knotch
this will richen faster
You may have to rejet I had to on my 185s
Jets are availlable still
Most MC shops still have assortments
your stock 200s has a 100 main jet you might try and get a 102 or a 104
My 185s had a bog from idle stock jet was 95 ended up with a 102
But I also have a header and Supertrap exhaust and opend up my airbox for more air flow
Thanks
Ray
Old Jul 10, 2008 | 10:14 AM
MonkOFox's Avatar
hell yea, I'll try that stuff and see if it helps it...
Thanks again,
Monk
Hankey Pankey
26
Oct 18, 2020 03:50 PM
VRRRRT
Jun 27, 2015 09:38 AM
robj
Jun 15, 2015 08:45 PM
DOAinNY
Jun 11, 2015 10:34 PM
200x hill climber
Ask the Editor
Jun 10, 2015 11:11 PM
