What size carb will work on a 107cc Jailing motor
Old Jul 14, 2008 | 11:28 AM
hwsmike's Avatar
Default What size carb will work on a 107cc Jailing motor
I currently have what I think is a 16mm carb (19mm opening at intake) that needs to be replaced. Can I use a larger carb without modifying the engine. I'm asking because everything I'm finding that will bolt on is either listed as 19mm or 22mm. If I go with a bigger carb do I have to modify anything.
Is it possible that people are listing these carbs based on the intake opening size?
Old Jul 14, 2008 | 01:44 PM
luvmysxs's Avatar
the carburetor size is measured at the exit opening where it bolts up to the intake maniford, here it should measure .748 inch or 19mm. so if you measured 19mm across the intake opening then you need to remeasure at the exit where the carb bolts up to the intake maniford. you shouldn't have a problem going up to a 24mm carb as long as you take the time and have the knowledge to jet it correctly,
Hankey Pankey
26
Oct 18, 2020 03:50 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
JackOReilly
Dec 7, 1999 09:12 AM
