what jetting should i use
Old Jul 17, 2008 | 01:37 PM
Sontizzle's Avatar
Default what jetting should i use
heres the mods im going to be putting on
exhaust: http://www.rockymountainatv.co...Id=4635#vehicleSelect
header:http://www.rockymountainatv.co...Id=4628#vehicleSelect
air filter: http://www.rockymountainatv.co...d=16048#vehicleSelect
i guess ill have to run it without the air lid or can i just remove the whole air box since im going with the clamp on style filter?
sorry ive been asking so many questions lately but im new to yamaha
Old Jul 17, 2008 | 02:04 PM
firehog's Avatar
First, I don't think you will see any difference between removing the air box or running with no lid, so I would run with no lid so that would give you some protection, especially if a little water splashes. That being said, I would order a jet kit from someone like dynajet. They will give you everything you need for rejetting and a baseline to start. Usually, they are right on and make jetting easier. Just remember one important thing while rejetting: Always write down each step you make and the change you make and take one step at a time once you have established your baseline so you don't get confused. Good luck and enjoy your new mods, should give you plenty of added power. You may consider a new cdi box too to take full advantage of the mods you are adding!
Old Jul 18, 2008 | 01:13 AM
91Warrior357's Avatar
yes it does make a big difference in power with your lid off, but in return your jetting has to be richer and it will be a little harder to get jetted right, you dont have to run with it off but if you like a deeper sound and a lil bit more power then thats usually what u will get but i wouldnt recommend running no lid unless u have an outerwear
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
