top end kit trail boss 250
Old Jul 24, 2008 | 12:19 AM
juttin_15's Avatar
Default top end kit trail boss 250
does anyone make a top end rebuild kit that includes jug and piston and power reeds?
Old Jul 24, 2008 | 06:27 PM
Stout's Avatar
Are you trying to install a reed cage on the 250?! I've never seen a set up like that available but have thought about building something like that many times. Those motors can really rip with some porting and planing the head.
Old Jul 24, 2008 | 07:38 PM
ftwflh's Avatar
HPD used to make a reed conversion for the 250s
But you can get good power by porting the cylinder and milling the head .020
Old Jul 25, 2008 | 09:09 AM
Stout's Avatar
If you are really looking to make some power out of the 86 trailboss, look at the 87 cyclone service manual. the cyclone was basically a factory modified trailboss engine. The head on the cyclone has .060 to .080 less squish than the trailboss. The timing is advanced almost as far as it will go and it runs a 34mm carb instead of the trailboss's 28mm. The cylinder is ported much more than the trailboss as well.... These things as well as the correct exhaust and clutching and you should be able to beat some stock 400Ls in a drag race.
oliveiracarlos
19
Nov 11, 2015 05:49 AM
craacker
Sep 9, 2015 04:32 AM
awer1968
Sep 8, 2015 11:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
Canamaniac!
Sep 4, 2015 06:44 PM
