polaris
Old Jul 28, 2008 | 10:01 PM
tim001232's Avatar
Default polaris
i have a 2001 polaris 250 trail blazer and recently it stalled and now i can't get it to start i changed the spark plug and used eather and it still won't fire anyony have a suggestion i checked the compression and it is showing 60lbs
Old Jul 28, 2008 | 10:02 PM
Sidewinder500's Avatar
Default polaris
i believe the compression should be up around 120, sounds like time for a rebuild
Old Jul 28, 2008 | 10:07 PM
tim001232's Avatar
Default polaris
that sucks i just did that last year
Old Jul 28, 2008 | 10:10 PM
ncriderforks's Avatar
Default polaris
When you rebuild it again check for intake leaks and crank seals for air leaks. Both can cause lean conditions and will burn up th rings way quicker than normal
Old Jul 28, 2008 | 10:14 PM
tim001232's Avatar
Default polaris
thankz i didn't do that last time
Old Jul 29, 2008 | 12:44 AM
MagnumPO's Avatar
Default polaris
may need a rebuild but before you do that...
*make sure that the compression is supposed to be 120, for my magnum the book says 50 to 90 which would make yours good at 60 but I dont know if its the same
*check your flywheel key. mine sheared a couple of months ago and it took a while to figure it out. I had spark and fuel but essentially the thing was way out of time.
I would just check the simplest things first before tearing it apart. Just my opinion.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
