Light and work lamp Modifications
Old Jul 30, 2008 | 01:19 PM
coacho's Avatar
Default Light and work lamp Modifications
Has anyone did the head light modification where high beam has all lights on and has anyone did the rear work lamp switch. Was it hard to do?
Old Jul 30, 2008 | 01:31 PM
02magnum500's Avatar
Gets his share of deer.
The kit is on http://www.quadovator.com/ for the 3 light mod.
Old Jul 30, 2008 | 01:34 PM
ATV_MAN's Avatar
For the 3 headlight you need to add a 4 pin SPST relay in the pod, it is not hard just a little wiring.
Old Jul 30, 2008 | 03:54 PM
coacho's Avatar
does the relay come with the kit form the above site
Old Jul 30, 2008 | 04:04 PM
700 sportsman's Avatar
ATV_man not to be an @$$ but you don't have to use a relay and you can get that same kit off ebay for $4 FYI
Old Jul 30, 2008 | 04:08 PM
and for the rear work lights you need 2 sylvania 912 or 921, the 921's are brighter, and I used a toggle switch with a rubber boot/ nut to make the switch waterproof, but you can use whatever switch you want
Old Jul 31, 2008 | 05:23 AM
bbsq00's Avatar
Rear light not a problem, five minutes with a switch in the pod. On the front I did my own, with a relay and a switch now I have Low, High, and three light option!!!!!
bzdok1234
30
Feb 23, 2016 01:55 PM
ranvette
Jul 4, 2015 06:13 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
