2001 sportsman 90
Old Jul 30, 2008 | 07:37 PM
cass hedley's Avatar
Default 2001 sportsman 90
2001 sportsman 90 it runs good but the first time you crank it you have to kick it about seven time it has a ele choke is this common
Old Jul 30, 2008 | 07:43 PM
vrodpredator's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: cass hedley
2001 sportsman 90 it runs good but the first time you crank it you have to kick it about seven time it has a ele choke is this common</end quote></div>
the 2001 doesnt have an electric choke my 01 90 eats spark plugs and batteries alot so be sure that those are in tip top shape at all times
Old Jul 30, 2008 | 08:59 PM
thanks the batt was low i did not thinkabout the batt because it does not need a batt to run but it prob does for the choke ill try a new batt
Old Jul 30, 2008 | 09:39 PM
The electric choke on 2000-2001 models didnt work that well,plus the newer ones with manual chokes if not started frequently are sometimes also hard to start. A little trick on all models is to block air intake tube with thumb while starting and usually starts quicker. Alows more fuel for starting.
Old Jul 31, 2008 | 08:48 AM
thanks i tried that trick and it works thanks old polaris tech your the man
Old Jul 31, 2008 | 11:59 PM
user493's Avatar
Moto Psycho
+1 You're the man. [img]i/expressions/beer.gif[/img]
Cole Hadden
Jun 15, 2025 09:05 AM
Hunter100us
Oct 7, 2015 11:46 PM
Aug 11, 2015 11:56 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
maxjung
Jul 14, 2015 03:10 AM
