scrambler 500 charging problem
Old Aug 5, 2008 | 12:52 PM
nick9882's Avatar
Default scrambler 500 charging problem
i have a 2000 scrambler,the battery will not hold charge,it is a new battery,anyone know what the voltage should be at the battery with the quad running,and do the scramblers have a voltage regulator,i dont see one on mine,so i guess that could be the problem too,i dont even know where it is located at on the quad
Old Aug 5, 2008 | 01:14 PM
atvaddict7's Avatar
Stator
Old Aug 5, 2008 | 01:35 PM
MECHANIKE's Avatar
non running 12-12.5v,running 13.8-14.5 depending how low the batt. is.............
Old Aug 5, 2008 | 11:28 PM
check reg/rectifier wires at front of machine(behind radiator depending on model) has red,yellow,yellow/red,and brown wire. if not charging close to 14 volts see if any of these wires may have been pulled loose. Have had this happen several times. if all connected,then must get resistance specs on charging coil from stator wires, yellow and white/yellow( i think), if good,replace reg/rect. In my experience usually pulled wires or bad reg/rectifier. Good luck
Cole Hadden
Jun 15, 2025 09:05 AM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 14, 2015 02:22 AM
maxjung
Jul 13, 2015 05:11 PM
Chocobamofo
Jul 10, 2015 07:46 PM
