1985 honda atc 125m
Old Aug 5, 2008 | 06:15 PM
corolla90's Avatar
Default 1985 honda atc 125m
i just wanted ur guys thoughs on this, i found a 85 atc 125m in fair condition, plastics are tore up, needs new tires but runs good, i wanted to know if its a auto and if it is , if u guys know how many gears it has. and is it worth $275
Old Aug 5, 2008 | 07:31 PM
3wheelersforlife's Avatar
http://www.3wheelerworldforums...ite/85atc125m-110.html
Old Aug 8, 2008 | 11:55 PM
pcollins's Avatar
its semi auto. which means you have to shift, but there is no clutch, you just let off the gas to shift. and most have 4 gears. and the 125m's have a hi and lo range on their transmissions.
Old Aug 9, 2008 | 12:21 AM
taiser's Avatar
If it runs it's worth 275 without hesitation, but up here they are more expensive.
Old Aug 9, 2008 | 01:46 AM
corolla90's Avatar
where u from? here there pretty cheap i picked up a running 81 185s for $200 just needed new tires in the rear and fenders
Old Aug 11, 2008 | 02:11 AM
corolla90's Avatar
well i just bought another 3wheeler 85 200x, runs, but need new handel bars,light/housing,fenders,on/off and light switch. paid 300. does anybody know the easyest way to take out a broken bolt? i was taking the handel bars off cuz they are bent and i broke one of the bolts, the rest cane out easy. also how can i stiffen up the rear spring? cuz when i sit on it, it lowers a lot, im a heavy guy.
Old Aug 12, 2008 | 11:07 AM
pcollins's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: corolla90
well i just bought another 3wheeler 85 200x, runs, but need new handel bars,light/housing,fenders,on/off and light switch. paid 300. does anybody know the easyest way to take out a broken bolt? i was taking the handel bars off cuz they are bent and i broke one of the bolts, the rest cane out easy. also how can i stiffen up the rear spring? cuz when i sit on it, it lowers a lot, im a heavy guy.</end quote></div>
you'll most likely have to drill it out and then use a screw extractor. i had to do the same to a stabalizer bar on a polaris snowmobile.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Jason Campbell
Sep 7, 2015 02:25 PM
