Ground wire
Old Aug 5, 2008 | 10:43 PM
catsmandan's Avatar
Default Ground wire
Hey guys let me ask you a silly question i am putting back together a 1995 polaris 400 2x4 that i did not take apart put new engine in it and it runs by pull start but the starter don't work or any of the other lights or fan. I noticed that i do not have a ground wire on the battery i know a car battery grounds to the motor does an atv ground the same also the starter just has one hot wire running to it from the relay is this correct or is it supposed to have more wires thanks a bunch
Old Aug 6, 2008 | 12:19 AM
Default Ground wire
From neg side of battery,should have a wire going to engine case bolt for ground.You can pull start because old models magnetic triggered ignition,battery for starter and lights. Thats why pull staring with dead or dying battery usually pops lights as reg/rectifier power from stator has to go somewhere,if battery not accepting voltage,lights have the least resistance and will go.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
hueby
Aug 29, 2015 08:34 AM
frostphase
Aug 19, 2015 07:11 PM
Schneider
Jul 24, 2015 05:05 PM
chammerbeck
Jul 17, 2015 08:06 AM
