Check this out
Old Aug 6, 2008 | 01:12 PM
Koerbs's Avatar
Default Check this out
I got my Quadovator stuff the other day. Reverse lock for plowing, work light switch, fan override, and temp gauge.
I thought I'd try to mount the temp gauge down where the choke and diagnostic post was on the older machines, being my computer hookup in under the rack that hole was free.
The ring in the pod where the choke went is the same size as the gauge 1.5 inches. So I used my hole saw and punched it out. I made a angle ring out of pvc pipe and wrapped it with extra wide electric tape. The tape in the same finish as the bottom of the pod. The angle ring is 22.5 degrees.
I think it looks sweet where I put it and with the angle you can see it at most any position, I know it would be 100% visable on the top of the pod but I want to use the last knock out switch hole for hand warmers. So thats why I put it where I did.
Enjoy!!
Old Aug 6, 2008 | 01:28 PM
02magnum500's Avatar
Gets his share of deer.
nice use of space! yours idles at 1320 rpm? seems high.
Old Aug 6, 2008 | 01:39 PM
atv gooroo's Avatar
I was thinking the same thing.
Old Aug 6, 2008 | 05:08 PM
HIGHOCTANE's Avatar
Nice gauge install!
Mine idled at about the same RPM for the first 20 hrs or so, now it idles around 1250. Spec. is 1150 +/- 100, and the book calls anything above 1300 a "high idle" But IMO as long as it is not hard to shift or creeping it is fine. Matter of fact i know some techs who set the idle on the high side of spec. to remove some of the lag in clutch engagement. I would check the cable adjustment and if that is good I would roll with it as long as it shifts fine and does't creep.
Old Aug 6, 2008 | 06:12 PM
polarisman600's Avatar
Looks Good!
Old Aug 6, 2008 | 07:10 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
idle should be 1150 +,- how is it to see when your going down the trail? nice fitting though.
Old Aug 6, 2008 | 10:38 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Talking about the pics.......Nice, ..But what do you guys think about the needle speedo(MPH) gone for 2009?
I drove the new 2008 A/C TRV and it has the full digital speedo display and it's hard to see somethimes during the day!!........
Just thought I would ask,Don't know if the Polaris will be hard to see or not..........Caper..........
Old Aug 6, 2008 | 11:43 PM
jokout's Avatar
Caper, if it is similar to the 300/400 HO displays it will be fine! This setup works very well, it is visible in full sunlight!
Old Aug 7, 2008 | 05:36 AM
MaineWheeler's Avatar
I like the use you've made of pod, very professional looking job installing things.
Old Aug 7, 2008 | 05:43 PM
user493's Avatar
Moto Psycho
Good job Koerbs.
