Check this out
Old Dec 13, 2008 | 04:45 PM
*5 J's*'s Avatar
Default Check this out
Awesome idea. I just bought the Quaovator kit and wasn't sure where I was going to install the temp gauge as I already have the Turf Mode switch and am adding the Reverse Override and Worklight Switch. The would leave me no good location for the Temp Gauge. A search of the forum and viola! A great idea.
Anybody else mount the temp guage in other locations?
Old Dec 13, 2008 | 05:06 PM
Koerbs's Avatar
I will have to look into how you did that, I would like to get a temp gauge also and couldn't think of a good place to put it. Thanks Koerbs you are my hero...
Old Dec 13, 2008 | 10:22 PM
jodaanja's Avatar
What's a "Turf Mode Switch??
Old Dec 13, 2008 | 10:24 PM
user493's Avatar
Moto Psycho
<div class="FTQUOTE"><begin quote>Originally posted by: jodaanja
What's a "Turf Mode Switch??</end quote></div>
Rear dif unlocker on X2s.
Old Dec 13, 2008 | 10:27 PM
  #15
Koerbs's Avatar
The 1x4 feature on the x-2's, allows you to turn on grass or turf without tearing up the grass or turf. It is not a feature that can be added, not without some sweat and bucks.
Old Dec 14, 2008 | 07:01 PM
  #16
*5 J's*'s Avatar
Koerbs - a little tricky fitting the mounting bracket, huh? Took me a few times in and out to get it to fit tight. Also a little tricky getting the bracket nuts on. Finally, I removed the headlight and was able to get a nut driver on the nuts. That worked great.
I started with the 22.5 degree angle ring as you did. I angled it up then had to roll the ring in slightly to get the gauge to set square. I really like where it sits and visibilty is fine for me.
I installed the backup light kit, the reverse override kit then got the guage mounted and wired, however, I ran out of time and didn't get the sending unit installed yet. Next weekends project.
Old Dec 15, 2008 | 05:52 PM
  #17
Koerbs's Avatar
Yeah, the ring has to be turned a bit. And I had to fungswey that bracket to get it to fit properly. Its a custom job thats for sure. Lets see a picture....
Old Dec 16, 2008 | 08:21 AM
  #18
*5 J's*'s Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Koerbs
Lets see a picture....</end quote></div>
I take a pic this weekend and post. I leave my house in the dark and get home in the dark this time of year.
Old Dec 18, 2008 | 07:26 PM
  #19
sheepdogMSP8117's Avatar
VERY nice!
Old Dec 20, 2008 | 04:14 PM
  #20
*5 J's*'s Avatar
Couple of pics of the headlight pod with the temp guage, reverse override, and worklight kits installed - as well as the factory Turf Mode swich.
