02 Banshee won't start after "friend" rode it.
Old Aug 9, 2008 | 07:41 AM
Mishkin's Avatar
Default 02 Banshee won't start after "friend" rode it.
my "buddy" came over and rode my banshee.. well he took it out for a couple laps, went down pretty far away from me down a hill and must of left it in a high gear because I could hear it all bogged down..
then I didn't hear anything for about 10 seconds (i guess it died is what he said) and then I hear a loud POP like it was JAMMED in gear really hard and then he came back with it and when he pulled up it died and won't start AT ALL.
I let it sit over night and it still won't start.
it is getting spark, it got dark so I didn't check the fuel but i'm about to go do that as the sun is coming up right now..
it just kicks and doesn't even attempt to fire.
Old Aug 9, 2008 | 02:28 PM
duhameister's Avatar
It was probably loaded with fuel and when the bike shut off there was a little bit of fuel still burning off. I would put some new plugs in, but when you pull them out leave them out for 20 min. or so and let some of the fuel evaporate out, that way you get a fresh start.
Old Aug 9, 2008 | 05:54 PM
91Warrior357's Avatar
yea id try that first b4 thinking of anything else, a new set of plugs and either let the cylinders dry out or just kick it over wit ur hand with the plugs out and that will dry them out fast
Old Aug 11, 2008 | 03:33 PM
LarryP's Avatar
Check to see if the carb was blown out of it's retaining sleeve. My Big Bear has done that to me 2 or 3 times in the last month. I just loosen the retaining band, put the carb back in the sleeve and tighten the band back up. Agrivation, but guess that's better than getting an unwanted boom when the gas in the carb ignites from the backfire.
Old Aug 12, 2008 | 06:22 PM
bassballs818's Avatar
I would do everything that was mentioned here and if still doesnt start, then he might have blown the cam chain trying to shift improperly. This happened when I first got my Warrior and my "friend was trying to pop wheelies the wrong way. I was lucky though because it was still under warranty. The whole tranni was destroyed with shrapnal. Check it out.
Friend dont let friends ride without a downpayment[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 12, 2008 | 09:57 PM
1smokin50's Avatar
I would also look and make sure that the reeds didn't get ruined, they can break under a back fire then get sucked into the cylinder and ruin the motor...
Old Aug 13, 2008 | 11:36 PM
Doctorturbo's Avatar
GOT BOOST!
<div class="FTQUOTE"><begin quote>then he might have blown the cam chain trying to shift improperly. </end quote></div>
Going to have a very hard time finding one of those if he broke this on a Shee.
Do a compression and go from there.
Old Aug 14, 2008 | 01:12 AM
Sidewinder500's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Doctorturbo
Do a compression and go from there.</end quote></div>
LOL i noticed that too and wondered why no one was commenting on it
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
garyt1975
Jun 5, 2015 08:53 AM
Timjunior
Ask the Editor
May 28, 2015 01:09 PM
1000gade
May 27, 2015 12:37 PM
B4NSH333
May 26, 2015 06:55 AM
