coolant problems
Old Aug 12, 2008 | 02:24 PM
gomer4877's Avatar
Default coolant problems
ok i dont get this. my coolant will be full before i go for a long ride then the day after ill look and its really low. my temp light has never came on or nothing though and it doesnt leak at all from what iv seen. im confused. o and i got that hmf pipe. im in love. i would recomend it to everyone
Old Aug 12, 2008 | 03:16 PM
jusrlax's Avatar
It is normal for the reservoir tank to read lower when the bike is cold than it does when the bike is warmed up, even a little below the "min" mark. Is you oil level going up as you ride, or does you oil look milky and foamy? That would mean you are truly losing coolant into the oil, which would mean bad water pump seals or maybe a leaky head gasket.
Old Aug 12, 2008 | 11:11 PM
gomer4877's Avatar
last i checked my oil was just fine, and i know the cooland rises when its warm. but like before i go in a ride ill fill it to the min mark and then the next day it will way below the mark. itt check the oil after i rode it for a while. god i hope its nothing serious
Old Aug 12, 2008 | 11:54 PM
McKay5858's Avatar
i had a leak once that would only leak when it was right warmed up and i was under heavy throttle. wash your bike real well then see if you can find a leak after riding it. Also you can check if its comin out the tp of the resevoir you could be getting exhaust pressure in the cooling system but if its doin that you feel coolant all over your leg when your moving.
Old Aug 13, 2008 | 04:20 PM
gomer4877's Avatar
ya when i first got it i noticed after riding there was a wet spot on my leg but its not doing it anymore so i dunno
SDR-II
Sep 29, 2015 01:06 AM
ScopeZ_
Jul 28, 2015 01:44 AM
hondarider1234
Jul 21, 2015 11:53 PM
Coryco
Jul 6, 2015 07:30 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
