Tipped 85 ATC110 on rear to change tire, and now it won't start!!
Old Aug 13, 2008 | 12:01 AM
lukebuz's Avatar
Default Tipped 85 ATC110 on rear to change tire, and now it won't start!!
OK, I have a decently running 85 ATC110 - and I tipped it on it's rear to change a front tire I was having difficulty getting off.
It was upside down for about 3 minutes, once to get the tire off, and once to get it on. When it up tipped up, fuel was running out of some long black plastic lines. Not sure exactly why!
Anyways, now it won't start! Pull and Pull and Pull...nothing.
Checked the spart plug, not wet...can smell fuel, but it may just be the fuel on the floor...kill switch is on....tried with/without choke...nothing.
Any hints? Used to start on 1st or 2nd pull. Must be something to do with leaking fuel?
Thanks!!!
Old Aug 13, 2008 | 10:24 PM
splescort's Avatar
the ball float in your carb is cutting off the fuel some times boucing the bike a round a bit works or you might have to drain all the gas to get the ball to come down.
MikeyBoyesq
Nov 27, 2020 02:44 PM
txkevin
Sep 21, 2015 02:02 PM
rcappie4
Jun 13, 2015 05:28 PM
1000gade
May 27, 2015 12:37 PM
blaze_master
May 26, 2015 11:18 AM
