1987 TRX125 - front end questions
Old Aug 16, 2008 | 02:40 AM
big-john's Avatar
Default 1987 TRX125 - front end questions
My sons recently acquired a well used 87 TRX125 (Fourtrax).
A prior driver hit something hard enough to bend the front axle and tire rim.
We did find a replacement axle rather than trying to straighten the bent one.
Questions:
How easy is it to correct a flat spot in a rim that causes the tire to hop?
Or am I better off just finding a replacement wheel?
What is the secret to removing the long bolt that holds the front brake assembly to the axle? The bolt turns freely but doesn't seem to want to come out.
Thanks for any help!
Old Aug 16, 2008 | 06:41 AM
HondaMechanic's Avatar
The rims are almost impossible to get true once they get bent bad enough to wheel hop ..
The bolt is the kingpin , the knuckle turning back & forth will wear a burr on it then it will have to be driven out and a new one installed along with new bushings in the knuckles ..
JackTheKing
Jul 14, 2015 09:09 PM
1966F100
Jul 12, 2015 03:08 AM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
jettman
Jul 6, 2015 12:16 PM
