Polaris Scrambler 400 starting problems
Old Aug 16, 2008 | 11:22 PM
cordell222000's Avatar
Default Polaris Scrambler 400 starting problems
For some reason I am getting gas in the carb but it is not going into the cylinder. I tried to find some diagram of how the carb is hooked up, but only found the diagram only. Please help!
Old Aug 17, 2008 | 01:47 AM
Gee3's Avatar
Check for spark first. If it's there, pull the fuel line off of the carb and make sure you have good flow from the fuel tank. If that checks out good then it's probably time to pull the carb and give it a good cleaning.
Old Aug 17, 2008 | 09:53 AM
Got spark... got gas coming out of the fuel line.... just not getting gas to the cylinder. I will clean the carb.
Old Aug 17, 2008 | 10:15 AM
ftwflh's Avatar
Check engine compression.Bad comp will ne let gas into cylinder.Also check pipe for blockage such as mud and pull manifold off to check for raw gas in pipe.
Old Aug 17, 2008 | 10:52 AM
drlang's Avatar
reed cage???
Old Aug 17, 2008 | 12:08 PM
I just replaced the piston and rings.
Old Aug 17, 2008 | 12:09 PM
What is that?
Old Aug 17, 2008 | 12:11 PM
I also put my hand over the inlet and I could feel it suck..... and yes not have the ATV running does suck.
Old Aug 17, 2008 | 12:16 PM
Not the reed... I checked it before I put it back on.
ftwflh's Avatar
still do a comp check.A ring could have broken
