Polaris Scrambler 400 starting problems
Old Aug 17, 2008 | 01:04 PM
cordell222000's Avatar
Default Polaris Scrambler 400 starting problems
What should the compression be?
Old Aug 17, 2008 | 02:54 PM
ftwflh's Avatar
At least 100psi to start 120 psi to run decent
Old Aug 17, 2008 | 03:12 PM
That's it..... When I bought a overbore piston it seemed loose but the guy insisted that it was the right size.... That has got to be the reason.
Old Aug 17, 2008 | 03:47 PM
ftwflh's Avatar
there should be no more than .003 clearance between the piston and cylinder at any point.This is the max it can be.
hoopduerr
Jun 10, 2015 03:00 PM
dorene
Jun 5, 2015 05:25 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
1000gade
May 25, 2015 10:48 AM
