how to change oil on polaris 500
Old Aug 17, 2008 | 02:32 PM
DOC HOLIDAY's Avatar
Default how to change oil on polaris 500
please help,how do you change the oil on a 07 sportsman 500?do i really have to remove screen from back of sump?and if not do i have to prime pump?it looks like the sump has to be removed to get behind it.
Old Aug 17, 2008 | 02:37 PM
Koerbs's Avatar
Search you tube for a video, there is a guy that put out a oil change vid on a x2.
Make sure you use the polaris oil or the same wieght oil, anything less you risk blowing out your cam.
Old Aug 17, 2008 | 05:32 PM
colt100's Avatar
I didn't when I changed mine. I figure that every once in awhile I'll have the machine into the shop for some reason and I'll just have them do that part. I think that the most important thing is to replace the oil and filter with new.
I had read on here somewhere that someone didn't remove the screen after a few oil changes when when he finally did, there was nothing on the screen anyway.
That's just my opinion though and i'm sure some one will correct my thinking if I'm wrong.
Old Aug 17, 2008 | 05:44 PM
TLC's Avatar
TLC
Another lazy trick is start the ATV and let it run for 20 seconds or so and it will pump the additional cup of oil from the crankcase out the oil tank drain hole,insteat of removing the sumb drain plug.
Old Aug 17, 2008 | 06:07 PM
will i have to pime the pump?
Old Aug 17, 2008 | 06:20 PM
TLC's Avatar
TLC
<div class="FTQUOTE"><begin quote>Originally posted by: DOC HOLIDAY
will i have to pime the pump?</end quote></div>
No, you only prime if you disconnect oil line with the sceen connecter to the oil tank.
Old Aug 18, 2008 | 02:56 AM
crucial's Avatar
I removed the screen on my first oil change. I did it in case some kind of casting flash broke off in the first 25 hours. I don't plan on doing it again for awhile. Priming the pump was no big deal. I just followed the owners manual and it was simple.
Old Aug 18, 2008 | 11:51 AM
hunt1940's Avatar
http://www.expertvillage.com/v...34_atv-maintenance.htm
Old Aug 18, 2008 | 12:11 PM
TLC's Avatar
TLC
<div class="FTQUOTE"><begin quote>Originally posted by: hunt1940
http://www.expertvillage.com/v...34_atv-maintenance.htm</end quote></div>
Talk about mixed info. I tossed out the instructions out from the oil kit I bought from the dealer but i distinctly remember it saying I would need to buy a extra oil if the ATV is complettly drained of oil from oil Tank and sump.
The 2 quarts are just for the quick oil tank change alone.
Old Aug 18, 2008 | 01:22 PM
Spdecat's Avatar
If you watch the oil change video the man says when checking your oil that you do not screw the oil dipstick back in , but according to my 2008 owner's manual and the Polaris service manual that I bought they both say to reinstall the dipstick completely then remove to check oil level .
