help
Old Aug 19, 2008 | 02:32 PM
biglee's Avatar
Default help
help my wifes atv ran great when we parked it 8 weeks ago now it wont run unless its on full choke, or when i do get it to run off choke it wont stay running unless i hold the throttle open half way then runs like crap then it wont idel
its a eton yukon 2 150 thans lee
Old Aug 19, 2008 | 02:51 PM
DARETORIDE's Avatar
Default help
bad gas and carb/jet could need a cleaning
Old Aug 19, 2008 | 02:58 PM
kukerdan's Avatar
Default help
take this post into the kids/other atv forum
Old Aug 20, 2008 | 08:28 PM
biglee's Avatar
Default help
THANKS I GOT NEW GAS IN IT WILL TRY OTHER THANK LEE
Old Aug 20, 2008 | 08:39 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default help
make sure the air filter and exhaust isnt blocked.
Old Aug 20, 2008 | 10:27 PM
ftwflh's Avatar
Default help
Take the cab apart,take both jets out and clean them.You pilot jet is stopped up.
Old Aug 20, 2008 | 11:54 PM
RticKwad's Avatar
Runs Stealth!
Default help
Had same issue on the wife's SP450 (Must be a spouse thing, LOL).
I found that my carb was gunked up, had to take it apart and clean
it. A good set of Orfice needles did the job with wiping it clean using
Carb cleaner spray. Also the throttle cable needed some adjusting,
runs GREAT! If it has sat for a few months at rest do it anyways, as
the weather cold to warm to cold again cause the condesation to build
in the CARB.
Future prevention:
Recommend Gas stablizer fluid (any that recommended for ATV or Motorcycles)
and turn of Gas Valve off and run it till gas is out of lines when cunks out.
YES I AM SMARTER NOW! (LOL, I learn everything the hard way!)
FYI, two of the bottom two posters here recommended the following when
I had these issues, LOL. Kudos to the experts!
Regards,
R'
