Need new springs ?
Old Aug 19, 2008 | 10:10 PM
AZX2USER's Avatar
Default Need new springs ?
I have a 2007 500efi X2 with 2500 miles , it's used 80% single rider.The front tires lean in at the top about 25 degrees.I have more wear on the inside of the tread pattern.Do I need new springs? Spacer?
Can I dismount and mount the tires (rotate ) like a motor cycle tire.(seat the bead with out a high volume air source?)
Old Aug 20, 2008 | 02:44 PM
It sounds like the stock springs are done to me. I didn't like my front X2 springs either. They squatted way too much especially going downhill. I got a set of heavy duty springs from a Polaris dealer on eBay. I love the ride even more.
Old Aug 20, 2008 | 02:55 PM
MECHANIKE's Avatar
I PUT SPACERS UNDER MY SPRINGS.1/4" SPACER GAVE ME ALMOST AN INCH HIGHER+NICE+FIRM.STILL GOOD YEAR LATER...............
Old Aug 20, 2008 | 04:26 PM
RticKwad's Avatar
Runs Stealth!
Mechanike -
What kind of spacers? Where did ya get'em and for how much?
R'
Old Aug 20, 2008 | 04:58 PM
MECHANIKE's Avatar
WELL I ACTUALLY ADDED ABOUT 4 OF THE SHIMS THAT ARE USUALLY ON THE BOTTOM OF THE SPRING FROM THE DEALER IT JUST COST A COUPLE DOLLARS.I WAS SHAKING THE TIRES AT 12 AND 6 TO SEE IF THERE IS ANY PLAY IN THE BEARINGS+HILLIARDS AND ONE STRUT LIFTED UP TOO EASY,NOTICED THERE WAS SPACE BETWEEN THE BOTTOM OF THE SPRING+STRUT MOUNT AND ALSO NO SHIM.THE OTHER SIDE HAD ONE+WAS ALITTLE STIFFER,SO PICKET UP 7 MORE+ ADDED 4 PER SIDE WHICH ONLY EQUAITS TO 1/4 INCH BUT IT RAISED ME ABOUT AN INCH, CAUSE I MEASURED BEFORE+ AFTER.MAKE SURE YOU HAVE ENOUGH ROOM FOR THE SPRING TO SIT ON THE BASE OF THE STRUT WITHOUT IT SLIDING OFF+HITING THE SHOCK...
Old Aug 21, 2008 | 06:31 AM
user493's Avatar
Moto Psycho
You can also get spring pre-load adjusters and set them at 0, + 1/2", or + 1" depending on what you're doing. http://www.purepolaris.com/Det...463(PolarisPGACatalog)
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
chuck1177
Aug 11, 2015 03:22 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
