Help, my Grizzly needs some cooling!
Old Aug 20, 2008 | 06:12 PM
OutRacing's Avatar
Default Help, my Grizzly needs some cooling!
Hey all, I don't know if any one might have some suggestions for me, but I have a '98 Yamaha Grizzly, the cooling fan that is just in front of the oil cooler has quit running. It is very siezed up. When ever I run my utility quad now, the oil over heat light comes on. I looked online and went to my dealer, a new fan for my quad is about 350 bucks!! Does any one have a alternet soultion for me that might not put such a dent in my wallet? Thanks every one!
Old Aug 21, 2008 | 01:55 AM
HeftyLefty's Avatar
Try Dan's Salvage, www.danssalvage.com. Or an auto parts store.They may have a blower motor that will work. According to parts diagrams, your cooling fan blade comes off.
Old Aug 21, 2008 | 07:17 PM
cadillacdude1975's Avatar
http://cgi.ebay.com/ebaymotors...rdZ1QQsspagenameZWDVW
there is a used one on Ebay for 20 bucks.
Old Aug 22, 2008 | 12:29 AM
MyNameIsMud's Avatar
Im sure you can get an aftermarket one at a parts store just measure the size. Most likely end up with a more powerfull one
Old Aug 22, 2008 | 09:21 AM
CraZySteve's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: OutRacing
When ever I run my utility quad now, the oil over heat light comes on. </end quote></div>
Personally I would not be running that machine at all until you fix it.... As others have said... look around.. you should be able to get a small Automotive fan... even try the junk yard!
Check out Derale Tornado Fans -- they make small automotive fans for Radiators and for Oil Coolers... I believe the smallest they make is an 7"
I found a kit on Summit Racing - Brand new for $72.
DeRale 16507 7" Electric Fan Kit
Heck - You could even get 2 install one as a Puller fan - to pull air into the radiator...
Old Aug 25, 2008 | 09:44 PM
OutRacing's Avatar
Okay every one, I have looked at every suggestion. Every auto parts store the smallest motor is too big, I got one, but it wouldn't fit. It was too long. I looked at the one on ebay, not only was I too late, it is for a 660, I have a 600. That one cools the water on a liquid cooled machine, I need one to cool the oil. This sucks. Stupid Yamaha, The radiator leaks slightly now too do to a stick. A new raditor is over 400 bucks, that little fan is 400 also. If one more thing goes bad on this quad it will be cheaper to buy an entire new quad.
Old Aug 25, 2008 | 10:25 PM
CraZySteve's Avatar
what about an Automotive oil cooler? Looks like you can get a whole kit for $180!
Derale 13950 Oil Cooler with Fan Kit $180
Old Aug 29, 2008 | 06:07 PM
OutRacing's Avatar
Crazy Steve, thanks, but it was too thick to fit in there? any one else got any ideas?
Old Aug 30, 2008 | 03:01 AM
HeftyLefty's Avatar
Try here. Look at item #4.
http://www.cmacma.com/cmacma_t...ogies_files/motors.htm
Old Aug 30, 2008 | 03:22 AM
OutRacing's Avatar
Thanks HeftyLefty! I'll let you know how it works out!
Pgbama11
Jan 16, 2016 08:19 AM
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
